Discuss Gypsum based tile adhesive in the UK Tiling Forum area at TilersForums.com.
I
Ian
I did a floor with GBTA (from Creative Impressions) a couple of months ago and took a few pics along the way and thought I'd share them with you all.
A bit of background on this particular floor first.
It was pumped in on April 22nd (2011) at a thickness of 50mm and left to dry for 3 months (longer than necessary but one floor was a basement which held the moisture more than expected when tested with a hygrometer), when we were satisfied that it was dry enough the heating was commissioned and the laitence (which was minimal) was sanded off using a mechanical sander with a metal abrasive pad,
GBTA & anhydrite 011.jpg GBTA & anhydrite 012.jpg GBTA & anhydrite 013.jpg GBTA & anhydrite 014.jpg
This process removed the laitence and created a lot of dust! It was then hoovered very thoroughly ready to be primed.
ALWAYS WEAR A DUST MASK AND VENTILATE THE AREA YOU ARE WORKING IN!!!
After sanding and hoovering the area to be tiled was then given a 1st coat of the GBLC primer 24 hours before tiling was due to commence.
Once the first coat was fully cured a, second coat was required however, this was to be done in smaller sections (5 m2 at a time) and was tiled on whilst still tacky.
The adhesive itself was very easy to use and had a reasonable pot life (30-40 mins), one thing I will say is that when mixed in the bucket to the correct ratios, it looked too wet but, when troweled out held its ridges and didn't slump at all. With a 10mm round notch and back skimming I was getting between 5-6 m2 from a 25kg bag.
Anyone who has never prepped and tiled on a gypsum floor and are wary of them, I will say that if you follow the recommended curing times, prep the floor in the correct manner and tile using the appropriate products, you have nothing to fear. These floors are becoming very common now so, you will all have to face them sooner or later!
I
Ian
I was always told that the sanding should be done as soon as possible after screeding as the longer its left the harder it is to remove the laitence and reveal the aggregate,Ive never tiled on a low laitence gypsum screed, what's the benefit of this over to conventional gypsum screed ?
This was the 1st one I've ever done Gary and to be honest it was a steep learning curve, the laitence on these low laitence screeds is so minimal that the purpose of the sanding process is just to give the surface a key. I was given a lot of expert advice along the way from Alan Jackson (Ajax) and Sabo from Creative Impressions. The laitence was sanded early on (4 weeks I think) by the client but, only by hand, the mechanical sanding was done as a belt and braces back up as the plasterers had been in and 2 months had passed since the original sand.
I
Ian
If you are mechanically removing the laitence and priming - can you not just use your regular cement based addy of choice?
I did a couple of sample tiles on a primed area, one stuck with GBTA and one stuck with flexible cement based, then left them for 3 days. The GBTA needed a hammer and chisel to get it up and the cement based needed a wallpaper scraper! So yes some manufactures claim cement based can be used but for me, no way I'll take the risk
Ajax123
1,213
Lincolnshire
That is pretty typical of my experience as well.
Gazzer
Lol I did the same except I did a Gypfix tile onto sanded surface ( no primer), A tile direct to surface with no primer or sanding using SPF and a tile to a sanded and primed using SPF surface. All in a row in a cupboard area.
The tile direct to floor with SPF came away easily with the laitance on the under side. The tile with SPF onto primed sanded floor took a little more effort and the Gypfix was the most solid. they were all laid on the same day and left for almost a full week before removing. removing the Gypfix tile didnt damage the floor but the adhesive left on the tile and floor was quite tricky to remove.
Reply to Gypsum based tile adhesive in the UK Tiling Forum area at TilersForums.com
TF Group Please Join
Tilers Forums on FB
