Discuss Gyvlon floor.here we go... in the UK Tiling Forum area at TilersForums.com.
Del W
1,113
Canterbury
I will try to include as much detail as possible in the right order.Might have to break up into several threads so I dont get info over load.!!
Marble is rosso levanto. 600 X 300 X 20mm.Highly polished.
images
All to be laid brick bond.
Areas,ground floor & first floor.Both are solid.Total,205sqm.Each area comprises of walkway,hallway,and several rooms coming off of them.Same marble for all.
Wet ufh(using brown water,(waste)heated at a lower temp than clean water). Commissioning is taking place now.
Gyvlon has been down 8 weeks.Have spoken to "screed it".it is low laitance. www.screed.it. Thanks James for the info.No tech speak.
I will,remove high spots.(very few)remove loose material.No need to sand as it is low laitance.Screed is only a couple of mm out here & there.Will sweep & vaccum.
Ardex products being supplied are,addy, x7001.grout, mg dark grey,will be telling them to get me ardex p51 primer.(loads !). x7001 is ok to use with p51 primer on gyvlon say ardex.
P51 primer.. Dilute 1:3 ?
It comes in kgs not ltrs.
10 sqm per kg ?
Will be priming at least twice depending on absorbtion.
Will leave it at that for the moment. More to come.
Comments ?
Ps. comments just to this point. (expansion,decoupling,etc to follow) :thumbsup:
I
Ian
Del I'm doing a low laitence job at the mo and I did a sample tile using butech cement based addy (Porcelanosa), the floor had been sanded and primed and in all honesty mate it only took a scraper under it to remove it after 48 hrs. Porcelanosa themselves said the addy was spot on for the job, I disagree. Using a gypsum based addy to do the job with and have to say, it's impossible to get it off the floor after fully cured.
Sent using Tapatalk
Del W
1,113
Canterbury
Thanks Sir, have spoken to n & c lakeside,near dartford,closest one to me,if i wanted it now,no problem. not on general realease till next friday so it seems.Thanks to n & c lakeside. A lot cheaper than creative aswell.
You only used 5 bags... half day then ? :lol:
Gazzer
Late start, Had to set out too and move furniture out the room, finished at 4pm. 19m2 inc cuts....yeah a bit slow !! Thom.jpg
Reply to Gyvlon floor.here we go... in the UK Tiling Forum area at TilersForums.com
I have a project of tiling my kitchen floor in my hands and i want to do it right at once rather...
schakal
F
Good evening all. I need to tile the kitchen floor over the bank holiday weekend. We are having...
12K
Futuregrout
F
So... have a problem maybe some of you guys (and girls) might be able to help with. Laid a new...
19K
TF Group Please Join
Del W
Canterbury
Business Name
D W Tiling
