hair line cracks on wall tiles
spraggie
I have just tiled a shower using rapid set Mapei cement and 150mm * 70mm white bonded tiles onto a soid ashlar wall. Having grouted with grey grout I can see that about 10 tiles have hairline cracks. Two of these cracks continue across two tiles so would dictate that cracks were not on the tiles before. I am going to have to replace them but am worried that the cracks may continue to appear. Any suggestions as to what caused this as I know the client will be on my case tommorrow!! Cheers.
Hi and welcome....you say ashler wall, the only wall like that is a rendered wall with lines cut into it so it looks like stone work.
Hi and Welcome. Could be wrong but are the tiles very thin? maybe the rapid set drying so quickly is an issue??
Or the fact that the crack continues across two tiles might suggest a joint line in the substrate?
It's most likely movement in substrate, take the tiles off and you will see crack in substrate, replacing tiles will not help,
you might have to overboard the wall
good luck
The tiles are 6mm. I was thinking the same as the tile cement was going off so fast maybe it was affecting the tiles. Should I have wetted the ceramic tiles on the back first?
I have taken one tile of and cannot see any cracking in substrate. The cracks are litterally on the glaze and do not penetrate through the whoe tile?
sounds like slight shrinkage has moved the tiles a tad,and just cracked the glaze if its not gone all the way through,could be a bad batch of tiles/glazing,
or like you say,maybe if you soaked them,could of stopped them drying out quicker than the setting of the addy
Hi Flaggy don't like to contradict you but I wouldn't be a big fan of ready mixed adhesive, especially in a shower!
For me it would be tank the walls then just use a slow set cement based adhesive, would probably mean coming back to grout the next day but hopefully should leave you with no comebacks.
Sounds like crazing to me, this was a problem back in the day when tiles were fixed in sand and cement.
but would crazing follow the tiles right across a few in a line which he said,which would prob be slight movement causing the crazing phil?
Good point, not a normal characteristic in crazing.
Can you tell us exactly what the tiles are and where they came from please?
Are these cracks running through the body of the tile or is it just the glaze of the tile cracking?
Had my local topps come to me with a similar question late last year, they supplied a cheapish, glazed ceramic wall tile to someone and it looked like they were all cracking. It was a faulty batch of tiles.
So don't be too hasty in ripping them off and starting again just yet.
A lot of glazed tiles are prone to glaze crazing, this would not normally show up with a white grout but would with a grey etc..
Stress crack would normally effect the tile biscuit as well but as phil said sometimes on cheap glazed tiles the rapid setting and shrinkage of adhesive can craze a thinner tiles finish without cracking the biscuit and transfer through more than one tile in a line..
Sometimes these glaze cracks are already there from the firing process , so don't right off your tiling and just replace ones that are effected..
spraggie,
DHTiling,
spraggie,
DHTiling,
