Discuss half bond tiling around revels in the Canada Tile Advice area at TilersForums.com.
Protilers
not a window reveal....but, the principal is the same:
charlie1
Ok, think I follow you. On the above example I did not continue the brick within the reveal but you can do it if you want, here is another trick, just use full tiles then simply make the appearance of the brick bond continuing by taking one tile and make a 3mm pass over it with a good bridge saw to simulate the appearance of 2 tiles, less messing around.
Reply to half bond tiling around revels in the Canada Tile Advice area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
