Discuss Hardibacker Board & Homelux in the British & UK Tiling Forum area at TilersForums.com.
DazJWood
I am just about to install Hardibacker board to the stud partition walls that will be my shower cubicle. My plan was going to be to then put up Homelux matting before tiling over with travertine.
After reading all the literature on Hardiebacker boards I am now wondering whether the matting over the top is overkill. They suggest the use of a PE sheet underneath the backer board. Has anybody used this method? And where is the best place to buy this sheeting if it is the best method?
Thanks in advance,
Daz
wetdec
There is absolutely no advantage to using a cement coared or coated board in this situation.
You guys may like them but the expense, messing around, addition of fittings, fixings, tapes etc compared to a £7.50 sheet of plaster board makes them non starters imo. These boards are made out to be a must have item that cost the earth yet the main benefit over plaster board is they can be used if working with exceessive kg/m2..............:banghead::banghead:
This is not directed at you Daz.....................
Reply to Hardibacker Board & Homelux in the British & UK Tiling Forum area at TilersForums.com
Hello I need to rip out and refit my bathroom, including retiling a bath area which will have a...
Hi everyone. First time poster and tile diy. Thanks in advance for any and all help, tidbits...
5K
I would very much appreciate the advice of anyone who has fitted Marmox boards as I have decided...
6K
Hi again Last week several of you helped me out with advice for a wetroom floor. There were a...
6K
Dumbo
I
Evening folks.... I have a slight issue I could do with another opinion on. I priced a job a few...
6K
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
