DazJWood
I am in the process of doing my bathroom. (Actually I have been since February but that's another story ). I have bought marble floor tiles and the plan was to lay these on a plywood base. The floorboards currently in the bathroom are of the 18mm chipboard variety but unfortunately a number of them are water damaged. The one under the bath was completely sodden so I have already ripped that one out. After researching this forum and a number of others on the net I had come to the conclusion that the ideal solution would be to take up all the chipboard flooring and replace this with WBP 22mm plywood and tile over the top.
I am now wondering about the use of Hardie Backer board. I've read through their leaflet and this seems like another ideal solution. I could replace the damaged chipboard flooring with the same and then go over the top with hardie backer board.
Does anyone have any comments, preferences on either solution?
The hardie cement board is only 6mm thick. Is this a sufficient thickness to tile over to avoid movement?
Thanks in advance,
Daz
PS. I'm no expert diyer so go easy on me if I've suggested a wrong idea :dizzy2:
Thanks in advance,
Daz
