Discuss Hardie backer boards in the Canada Tile Advice area at TilersForums.com.
charlie1
Having recieved conflicting fitting guidlines from hardies tech dept i decided to call them up again. There answer re fitting 6 mm boards to timber subfloor, Should be glued and screwed, but IF excessive bounce in floor then this has to be addressed first! I asked him to define excessive bounce but he could not. Can any of you guys give me the definative answer to an excesively bouncy floor because in my experience there is always movement in a timber floor!
Rookery
Yes all manufacturers will find a get-out and in their eyes its usually fixer error. Trouble is, it usually is fixer error by those who dont know or dont care enough to get it right first time.
Its difficult to measure bounce. To justify me over-boarding with Hardie, I show the customer how much bounce there is by putting my pendulum laser on the floor and walking (Not jumping) around and they can see the beam bouncing up n down. Most customers can understand that a rigid tile glued down wont bend and therefore thats why they're paying the extra to get the job done right.
I think there is a calculation for measuring the deflection, its something like: joist span divided by 360 equals allowable deflection. So therefore a joist span of 450mm will have an allowable deflection of 1.25mm. Christ knows how you'd measure it though. It may not even be true, I might have imagined it. At the end of the day the fixer has to make the call.
charlie1
why would hardie need a get out clause...? they provide a decent surface to tile to, its up to the experience of the fixer to prep the floor, if you dont know whats suitable to tile to, then imo you shouldn't be doing the job, as it will be nothing but guess work...
Hardie claims there boards can be used instead of plywood. The only reason i use ply is to stiffen up a wooden floor so to me they are claiming there boards will stiffen up a wooden floor sufficiently to tile too. If they dont have and anti flexing properties then whats the point in using them? Ply can be tiled to no problem.
Dougs Third Go
but you still wouldn't tile a ply-wooded floor that had deflection, well I wouldn't anyway.
The Legend; Phil Hobson RIP
This is exactly how I check for deflection, I set my self leveling laser on a tripod, and then walk around the room. It works for me, I do believe that Hardie board glued and screwed does improve rigidity on a wooden floor. I have done the same test with the laser after boarding, and seen a vast iimprovement. But as above the floor should be braced prior to boarding.:thumbsup:
The D
Hardie backer boards will not swell or contract with the changes in temperature and moisture content in the air they will remain stable even when submerged in water they do not rot they do not promote the growth of black mold and they make a perfect sub-straight to receive tiles.
I think this is the point you are missing. If you are using this type of board to strengthen a floor then you are misusing them and if there is ever a problem with your floor there is only one outcome, incorrect use of the product and that IS fixer error not a get out for the manufacturers.
Reply to Hardie backer boards in the Canada Tile Advice area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Hi Everyone, I have recently started the task of renovating the bathroom in my flat and am at...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
