Discuss Hardiebacker v's Ply confusion in the British & UK Tiling Forum area at TilersForums.com.
H
Holohana
Hi all, hope you can settle some confusion ive got.
Ive got a job where im doing some floor tiling and the builder is boarding out the floor for me but called today nd amongst other things asked to see how I would do it.
Told him I’d use Hardibacker, he was using 6mm ply himself and always does, and id lay this on a bed of flexible adhesive then screw every 300mm.
The area is 85m2 so comes in at just under at £1,000k for the boards plus addy plus labour. He balked at the total cost and said he’d just use what he’d already planned to do.
My labour was dirt cheap to lay the board, £100 a day, as got a free week and could do with a week of simple screwing.
The board going into 8 units all the same size so cut one lot of board and you’re away for the rest so really easy.
Joiner quoted £10m2 for laying ply plus ply so I’m well cheaper on labour and frees him up to crack on with other stuff on the development.
Now this is where the confusion starts.
When laying Hardibacker, 6mm on floors as per the spec which to start with I think is too thin, it states that you need a bed of adhesive applied with a 6mm notched trowel and then screwed.
My question is when laying simple plywood over boarding why don’t you need to use a bed of adhesive in that instance?
Technical at Hardi said its to make sure you don’t have any air gaps under the board which would allow movement and cause problems.
I get that point but couldn’t the same happen when laying ply?
Thanks in advance for what im sure will be compelling reasons why you do for one but not the other.
GazTech
If this 6mm backer is onto chipboard then fine, no addy reqd. I have never had problems, but on T & G it's different story....Gaz
H
Holohana
floor is chipboard on 2 x 2 joists. All small units totalling 85m2 with the max area being 5m2. Office toilets x 2 in 8 seperate units so not one massive area.
Builder is using 6mm ply so in theory he should be using adhesive too then?
I thought 12mm would be rigid enough, guess you could still have gaps though?
Ive never had problems either but always been domestic, not commercial and not 85m2 polished porcelain!!!
GazTech
Fair point cover all your bases on this one Holo....Gaz
DS Tiling
Sounds like the old story, builder is trying to save money by giving you at the least a concern. I am with the others in that if he doesn't prep the job the way you want then it is not worth the hassle. However if it is small units and you are happy that the floors are rigid enough with 6mm ply then that is your call. The 6mm hardi would be more rigid than the 6mm ply but it looks like he doesn't want the extra expense.
sWe
The area is 85m2 so comes in at just under at £1,000 for the boards plus addy plus labour. He balked at the total cost and said he’d just use what he’d already planned to do.
:47: He balked, and then disregarded your professional advice? I'd walk. Really, I would, and that's not even considering the price is nigh on ludicrous. I wouldn't ever do something which I couldn't leave a warranty on with good conscience. If I was short of work, and I needed the job anyways, I'd make the customer sign a waiver, which would stipulate that I couldn't be held responsible for any potential troubles caused by the substrate.
Reply to Hardiebacker v's Ply confusion in the British & UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
