Discuss Hardwall in the Australia Tiling Forum area at TilersForums.com.
TJ Smiler
Anyone used this before? doing a bathroom up and gone back to block walls, was gonna dot and dab PB but then i fancy trying something else, i'm pretty quick at plastering and i see the setting time on hardwall is 2 hours (also want to know if setting time means dry?)
Any info you got would be faaaaantastic
Chjeers
TJ Smiler
Thank you chaps...... Stick with dot and dabbing on this one then me thinks. Seems to take me ages to dab out a bathroom in PB, i think i may be going over the top with the amount of dry wall adhesive i use. I normally frame the board (on the wall) then fill this in with loads of rows of big dobs, almost like i'm trying to go for 100% coverage or something!! I know the stuff sticks like there is no tomorrow so i keep thinking i should use less.... I know you both dot and dab so how do you's do it? Hard question to answer i know, as it varies from wall to wall but as a general rule how many rows are you putting in per board. I gotta speed up on this front
Cheers lads
TJ Smiler
Thanks mate, yeah i'm using far too much then!! I knew i was!! on an 8x4 sheet i'd have about six rows or tons of dabs everywhere so there is no greater gap between dabs than about 3 bloody inches. My dabs are very fat too, i can use on some walls nearly a whole bag on one board (never been shown otherwise so always go overboard... pun intended)
Silly question mate but a good one for my knowledge, would your rows have gaps between each dab from top to bottom or do you do it so you have one continuous line?
White Room
Yes, usually about 150mm but I fix a dab at the top and bottom of the board between each row and if there is going to be skirting then a continuess row at the bottom for fixing skirting.
If there is going other items fixed to the wall ie sinks, shower frames etc extra dabs to assist with fixings so it dos'nt drag the board in.
Another point is where most forget is around the ceiling lines there are usually gaps, these must be filled as well and and holes where air can flow behind the boards, external walls must isolated again to stop any air flow behind the boards.
Cold air and hot air can cause alot of condensation so a point to think about. [MENTION=13634]TJ Smiler[/MENTION]
White Room
Yeah something to do with the fire traveling up the void quicker
Do you mean the void behind the plasterboard which should only be 10mm anyway, to be honest if the fire is burning that fierce you won't be getting out.
If you use thermal backed boards they use only 2 screws to hold the board on as heat/fire can melt the backing...imagine the fumes off that lot.
prceramics
http://www.british-gypsum.com/~/med...Leaflets/General/LIT_InstallationGuide_02.pdf
Using a trowel, apply a continuous
band around the perimeter of the
wall, ceiling edge, and around any
services or openings to provide
greater airtightness.
Airtightness
If a wall or ceiling is not airtight, air will pass through gaps, allowing
heat, noise or fire to escape. This can happen at the edges of linings,
such as where one wall meets another wall, floor or ceiling, and where
boards are cut to allow pipes or cables through.
To ensure the lining or partition is airtight, seal all joints and gaps
using Gyproc Sealant or Gyproc Dri-Wall Adhesive when using the
DriLyner systems
White Room
Airtightness
DriLyner systems
That is new to me, the rest is standard but they have included the fire bit....
Reply to Hardwall in the Australia Tiling Forum area at TilersForums.com
  • Sticky
Hi - we would very much appreciate some advice. In October 2020 we had a sole trader come in to...
Hi, my name is Eddy, my forum nickname is Dobalganero. I am looking for advice here. I hope I...
Lois Lane
L
Hey, this is my first time attempting to tile in my first home. Did a bunch of research last...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hardwall
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
