Hardy backer 12mm. Is it possible to dot and dab using thickset adhesive?
I
inspectapart
Hi, I just need some help with fixing 12mm hardy boards. I have ixed the two walls that are studded using drywall screws....seems to be O/K so far. But I have to cover an old brick wall also. I took of the high spots and primed it using ULTRA PRIME FLEXIBLE adhesive DILUTED 3 TO 1. I WAS HOPING TO DOT AND DAB THE BOARDS ON WITH ULTRA PRO RAPID ADHESIVE. What do you think?
The wall is pretty uneven but plumb. 1/2" of dab would allow me to level up I think.
The alternative is to battern out and that would mean a lot of packing out the batterns to get it level.
Hope this makes sense.
Bob
Hardibacker do not advise it..
You can use a marmox type board though and D&D that onto the walls with Adhesive, and then mechanical fix as well through where the dabs are.
If I use Marmox, Which adhesive should I use/ It would need to be a thickset type to get over th uneaveness of the wall
Haven`t picked the tiles yet but they will be Just ordinary 9mm wall tiles. No great weight to them.
Bob
I only use backerboards on floors. The good point of a backerboard is that it doesn't deform if it gets wet, tanked plasterboard will get you the same result.
Also backer boards hold a lot more weight.. if the choice is there then use backer boards IMO..
I`m totally confused now. I have been told that unplastered plasterboard is fine to tile over??! If that`s the case, why use backerboards at all for ordinary tiles? Also, I thought that water can get through the grout, and if so, this wouldn`t be a good idea would it? And why don`t hardi recomend dot & dab ? I could still screw and plug through the dabs for extra strength maybe?
I might just d&d plasterboard and tank it. I just removed all the old tiles from plasterboard and it wasn`t a pleasant experience. I ended up back at the studding.I thought that baackerboards might allow for easier removal of tiles next time??
Bob
10 years!!! But that doesn`t answer my question. ,,,,,,,,, Can I dot and dab Hardi backerboards ??
you can use either backerboards or you can use plasterboard and tank it either way its fine but hardi dont advise dot and dabbing the boards
inspectapart,
devonmark,
inspectapart,
devonmark,
