Have a washer and dryer with related power supply issue Discussion ThreadHave a washer and dryer with related power supply issue Electrical Advice
Have a washer and dryer that are plugged into separate sockets and both have 13A fusesl The electrical wiring passes through the washing machine socket and then on up to the the dryer socket above.
There was no power to the dryer so I changed the fuse in the isolator and now it works fine.
But for some reason, the lower washing machine socket now has no power. I tried replacing the fuse in the isolator switch first, then the fuse in the washing machine plug. No joy.
So what else do I need to test and in which order?
Thanksssss
Have a washer and dryer with related power supply issue for the original thread on Electricians Forums
Thanksssss
