Hi
I have a wood burning stove in my fireplace. It has generated a really good heat but unfortunately the surrounding plaster has blown. I want to
tile the recess with large Travertine tiles but I am unsure of which adhesive to use. It has been suggested thst I use a fire
cement. Can anyone advise.
Terry
Helo Terry,buy bal rapid set white,patch the plaster with it and use for the tiling..it must be white to stop bleed through of colour to the face which you may get with grey adhesive.Also use flexible grout and seal the tiles before grouting....these are my recommendations for your job.....Gaz
BAL Rapidset white
cement-based, polymer modified, non-slip, rapid setting, water-resistant and frost-resistant adhesive suitable for fixing ceramic wall and floor tiles including fully vitrified and porcelain, ceramic mosaics, quarry tiles, dark natural stone, terrazzo and brick slips. Suitable for a variety of backgrounds/bases including concrete/brick/block walling,
cement:sand rendering, gypsum plaster, plasterboard, fibre
cement sheets,
cement:sand screeds, ceramic/quarry
tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt. BS EN 12004 C2FT Adhesive.
NOTE: The physical properties of BAL RAPIDSET with Porcel Bond Plus can be enhanced by the addition of BAL ADMIX AD1.
bal superflex wall grout
A brilliant white, water & frost resistant cementitious wall
tile grout with built-in admixture to give increased flexibility and high bond strength. Suitable for grouting porcelain, marble, natural stone, glass and ceramic mosaics, glazed and fully vitrified tiles. BS EN 13888 CG2 Grout.
FILA UNPLSHD TRAV/MARBLE IMPREG SEALER http://www.tilersforums.com/redirec...rchval=&offset=6&action=&actionsearch=go&gid=http://www.toppstiles.co.uk/productimages/fullimages/Travertine%20&TM.jpg
