Guest viewing is limited
Discuss Hello folks! And a Novellini question in the British & UK Tiling Forum area at TilersForums.com.
Taylortwocities
Hi there chaps and chapesses,
I am about to embark on a small ensuite revamp which will involve installing a linear shower tray. My plan is to use a Novellini preformed tray with Tilesafe membrane. The walls of the room are rather not so good so I'm planning to support the existing and then over line the two walls that will be the shower corners with Wedi 10mm board.
I'll be doing that myself as I'm a pretty competent DIYer and an electrician by trade (don't mark me down for that!). I'll be getting a pro in to do the tiling.
Two questions for you:
1. I had heard from someone that Novellini isn't that well regarded and there may be problems with it - any opinions?
2. Any comments re use of Tilesafe with Wedi board
Thanks for your help!
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
Because that Flexi Fix thing is useless. It isn't going to create a water tight anything. Even in the picture on that website it is showing it being fixed to plaster. This means when the water soaks through to the plaster, and then runs down within the plaster (as we all know it does) it'll just go past the Flexi Fix and still damage the substrate and wouldn't have done a single thing to prevent anything.
A poor product even for DIYers.
You need to create a waterproof layer between the tiles and the substrate if the substrate is water sensitive as grout and adhesive is NOT water proof. It will allow water to pass through it still. So the flexi fix thing there will stop the bottom 2 inches of water getting to the back of the tile but not the other 7' above it.
Taylortwocities
OK, Thanks for your input. Rather than head off down a Flexi Fix cul-de-sac. I need to make some firm decisions.
As nobody has said "Novellini is rubbish" I can assume its OK - its only a composite tray so what could go wrong:wacky:
Wedi board seems to be a well regarded method of providing a water-resistance background to tile directly to. Yes?
Novellini recommend using Tilesafe as the way of providing a water impervious barrier to the floor and up the wall to go under the tiles and apparently is very sticky.
Are there any problems in this plan assuming everything is installed to the manufacturers instructions? Don't want to spend a thou on the shower tray etc only to find it is no good.
Thanks again for your input.
Reply to Hello folks! And a Novellini question in the British & UK Tiling Forum area at TilersForums.com
Please see rough sketch. My ensuite is 2x2 m with the door opening into the left into the room...
Hi, I am in the process of tiling with subways and just wanted some help with corners, if trim...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Good afternoon all. I am a keen DIYer (at home) but have never tiled! I want to tile our small...
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
