Discuss Hello from alba820 in the UK Tiling Forum area at TilersForums.com.
alba820
Grout Discolouration - The Question
Hi Folks
A newbee to the forum and joined up prior to starting a total refurb of our small en-suit shower room (timber frame bungalow).
Have taken a lot of time ensuring things prep'd and finished with care, new walls, floor, plumbing etc.
Have hit the problem of patchy discolouration of some of the grout lines on two of the walls !!!!!
The room has not yet been used and the tiles after fixing were not grouted for several days.
Bal flexible blue star white adhesive used and white bal grout to finish.
Interestingly the discolouration is on both a wall finished with mapei shower waterproofing kit and one that was not.
Substrate is green plasterboard, sealed to mapei spec all walls.
Having just checked the depth of discolouration, it seems to be in the top 1mm and I assume is bleed from the biscuit. Still to explore further.
THE QUESTION to you whizz kids: If I rake this out & re-grout, is the discolouration likely to re-occur and if so would spraying the joint with grout sealant, pre grouting, resolve the issue ?
Have found the forum to be a source of great help and ideas - many thanks to you all.
Reply to Hello from alba820 in the UK Tiling Forum area at TilersForums.com
Hi, I'm just saying hello. I've just joined the tile forum because I'm looking for some...
Italy
I
11K
Rizzle from the Portizzle
K
Hello I thought i would stop by and introduce my self as I have a feeling im going to be...
N
Hello everyone a very happy new year to you all!! It’s been a while since I last posted...
13K
Gazzer
Hello. My first post. After having good search, these tiling forums are the best I have come...
I
Hello from alba820
