Discuss hello new member in the Canada Tile Advice area at TilersForums.com.
dancn
Hello Folks,
Finally getting around to laying some wall tiles, and I'm looking for some help from the experts.
Ensuite 1165 wide. I have a window 550wX1050h which is offset, just under 250 from right side.
I'm using 365X250 laying portrait.
I have juggled around the layout, the best I can come up with is just under full width tile to right, and around 156 on the other side.
I tried centring from wall, and from window, but the cuts are skinny. will it look ok as i'm planning?
I'm going to tile the reveal and sill also, and use a chrome trim. Any tips for what stage to cut and lay the trim?
thanks for reading
dancn
Thanks Bri
heres a pic, to the right is just under 250, walls and reveals are pretty plumb.
centred from window width or centred from wall width leaves thin cuts. Maybe a trained eye can see better
dancn
I looked at landscape but I'm trying to stick with portrait on this room if possible. Shifted to centred around window, even cuts around reveal, near full tile to left wall.
The trim what best way to tackle this,any benefit to dry fix the trim before i start. other than tile and bed thickness in the reveals is there anything else I need to factor in?
I wouldn't fit the trim 1st. Very unlikely it will be in exactly the right place, with tiles to fit nice and snug. There's lots of threads on here, do a quick search. But easiest way for me is to tile the face of the wall 1st, then trim to be applied when doing the inside reveal cuts. Do the wall 1st then come back!
Reply to hello new member in the Canada Tile Advice area at TilersForums.com
Hello all, Joined the forum to hopefully read and pick up advice on tackling some home tiling...
Good afternoon all. I am a keen DIYer (at home) but have never tiled! I want to tile our small...
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
uHeat and TilersForums.com go Way Back - And Continue to Partner-up to Bring You Savings on...
hello new member
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
