Discuss HELLO TILERS! Please hep do I need a decoupling membrane?? in the British & UK Tiling Forum area at TilersForums.com.
MISSTEE38
Hi everyone! Ive got on here as I am a non tiler, but we are currently about to put down 66sqm of bottcino marble flooring, we are nearing the end of a big renovation. Our builder has installed a 50mm screed over wet ufh. We put it down middle of Dec and have been using the heating as we are having to live in the building site. I have read on here that we should have had joints put in at doorways and where we have different temperature zones which they haven't done. I notice now that we do have hairline cracks on all door ways, but builder says its nothing to worry about. We are about to employ a recommended tiler from a Tile Choice shop, who has been tiling for 30yrs and he was going to lay tiles straight onto screed with a flexi adhesive. Is this going to be ok, as another tiler had asked if any of my other quotes were laying a d coup membrane, which they weren't. Now I am very worried we will have trouble if we don't put the membrane down, any advice appreciated. Thanks.
MISSTEE38
Hi i think its the one people mention on here alot, but don't know the proper name, is it anhydralite or something like that..??!! Sorry to be so ignorant but the builders sorted it. It was a liquid screed and it went off in about 3 days, to be able to walk on it. I will ask my builder on monday i think the company who put t in were 'screed it' if that helps. It was 50mm deep.
Time's Ran Out
The type of screed is important for drying times, surface preparation and adhesive type, but if you have hairline cracks already showing a decoupling membrane such as Ditra matting would be strongly advised.
For the doorways, edges and break areas in the screeding process - movement joints should be continued through to the surface of the marble.
MISSTEE38
Hi
And thanks for replying, my builder says its a calcium sulphate screed, or gypsom based?? Is that any help? What sort of primer and sealant should I put on? I was sold Larsen white flex adhesive to go withthe marble tiles and a penetrative sealer. But we are not sure about putting a membrane down?
Any advice appreciated. Thanks
Thespanishtiler
turn off the ufh
test the floor for moisture level with hygrometer to the data relating to the floor you have had laid
if ok to proceed then scrape off any debris and friable material.
sand the floor and vac up the dust
prime to consolodate the subtrate
use nicobond gypfix addy to lay ditra uncoupler
tile with your spf addy
clean and seal
grout and clean
seal
polish
leave 7 days then bring up ufh in 5 degree increments
put exp joints across door ways and bay up any large areas
MISSTEE38
Brilliant thank you very much for the good advice. I realise you can't comment on someonelses ability, but do you think i could get my tiler who has never laid tiles on uhf to do this, he has 30 yrs exp and comes highly rec from tile choice but he hadn;t heard about a decoupling membrane, if i purchase it will he be able to lay tiles as normal but on the membrane is there more to it or should i get someonelse with experience?
Reply to HELLO TILERS! Please hep do I need a decoupling membrane?? in the British & UK Tiling Forum area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi I am posting in the hope that someone may be willing to offer me some advice about floor...
Hi Looking for advice for decoupling membrane. I have around 60m2 to tile with 20mm limestone...
After some advice please..... We have approx. 50sq m of Dijon limestone 600 x 90 x15mm and also...
Hello we are currently trying to choose a tile to lay on the ground floor (70m2) of our house...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
