V
vvvvw
Hi
I am ready to tile my bathroom floor its about 5m2 max and at the moment its stripped to the joists fo plumbing.What would be the correct way to go.I cannot feel any deflection if there is its minimum.There seem to be so many different oipinions of what one should dne independent tile retailer said always lay ditra matt wether installing UFH or not.Thought that only help lateral defection and not vertical.Some people say 18 - 20 mm ply others say moisture resistant chipboard flooring others say 18mm ply with 6mm backer board.
Please can anybody out there clarify.All i am after is a tiled floor possibly with UFH but a floor that has a reasonible chance of not failing in 6 months time.
Many thanks :yes:
Martyn
Many thanks :yes:
Martyn
