E
Evilc
Hi, this is my first post on this site so please forgive any silly thoughts.
I am gutting my kitchen and have purchased 15 sq m of porcelain semi glazed tiles 600x600 mm. I have read loads and discover that I need to put down a new subfloor and rip up the current old chipboard. My intention is to put down 25mm exterior grade plywood onto 400mm spaced joists and prime back and edges of plywood with APD, put in support noggins at unsupported edges and screw down with spax screws every 300mm.
However I am confused about which of the myriad of adhesives. I bought some weber.set SPF but now think this is probably wrong for such large tiles. I understand that the rapid set adhesives may be a little more flexible but as I am not an experienced tiler I am wary of being good enough to use it before going off.
Anyway, I would appreciate advise on 1) am I ok with my floor spec? 2) which adhesive ( preferably Bal) to use? 3) using levelling clips & wedges? Many thanks
