Discuss Help! Grout staining porcelain tiles problem in the Australia Tiling Forum area at TilersForums.com.
Gumposam
Hi everyone,
I've just completed laying a bathroom floor with 100x100mm black and white unglazed porcelain tiles ( PEI rated 5) . I've also knocked up a test piece on which to test the grout, as I'm a bit wary of the textured surface of these unglazed tiles. The intended grout colour is black. I have treated the tiles with Lithonfin stain stop, same way as I have treated my test piece.
As you can see, my grout test has come out terribly, with the white tiles looking grey and like they have a 5 o'clock shadow. What would the best course of action be here? Treat with something else? What would you recommend?
Many thanks in advance
Tile Shop
Had a couple of queries like this recently. One option, grout them as they are, and clean them with something like the LTP Grout stain remover and a black pad emulsifying pad, but the best solution is to put a sealer over them first before grouting. They're porcelain, so this is not essential, but will help..... you can apply a temporary coat of their MPG sealer. This will sit on the surface and be naturally removed during the cleaning off process. Another one is the BAL protective sealer.
But be careful with both, not to get it down the joints as if it attaches to the sides of the tiles, it can reduce the bond strength of the grout which can lead to it cracking further down the line.
Bill
don't use black grout - trust me it is terrible and stains almost everything no matter what impregnator you use.
Use a dark grey grout for floors and within a few weeks of washing, the grout will be black anyhoo.
If you insist on a black grout, try anthracite from the mapei range. Seems about the best one to me for cleaning off.
Nice tiling btw.
Reply to Help! Grout staining porcelain tiles problem in the Australia Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
