Discuss Help Help Help in the British & UK Tiling Forum area at TilersForums.com.
Mr_Sweep
Hi All
If someone can help i've been looking into getting a tile cutter, but if i'm going to put money into it i would like to know which one is the best for the job as an all rouder its basically the tile jig v's the tile saw any advice would be very welcome its for floor and wall tiles ie an [SIZE=+1]1027 SiriTop Tile Cutter can anyone help!:huh2: [/SIZE]
Mr_Sweep
Hi again guys
original post
Hi All
If someone can help i've been looking into getting a tile cutter, but if i'm going to put money into it i would like to know which one is the best for the job as an all rouder its basically the tile jig v's the tile saw any advice would be very welcome its for floor and wall tiles ie an [SIZE=+1]1027 SiriTop Tile Cutter can anyone help!:huh2:[/SIZE]
i just noticed it missed out this bit, Maxitile 260 tile cutter has a rail mounted, sliding cutting head, which is a wet sliding head saw which you probably all know so my question is the wet saw v's dry drag and snap tool which is best already had numerous rpleys to this and thanks to you all but if you could spare another 5 mins much appreciated :stupid:
Reply to Help Help Help in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Help Help Help
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
