If each
tile is as per the shaded area then I’d say the minimum no. of tiles is 16!
This would give a ring.
The only issue I see with my method of completion and the information/details they have supplied is it’s based on a
tile of 150mm square. Because of the curvature of the circumference that ‘add the
tile size’ bit onto the original 300mm radius then the
tile size width will be 150mm+ the curvature. Not sure if there is enough information provided to do it exact and for me I’d overlay a 150mm
tile on each section to get the final piece.
I understand the project in hand and the need to work it through, but it would seem a better practical test then geometry.
Off topic but have you learnt Pythagoras theory yet or calculating areas?
