silver
Hi all, I haven't been on here in ages ..apologies for that.....time goes so fast.
But I hope its still possible to ask for some help or advice
In brief, in tandem to a plumbing company I have in the past undertaken the tiling work on two bathrooms.....and one shower room / wc
There have been problems.
The shower room / w/c needed corrective plaster boarding before I could tank & tile ....which when completed resulted in step ladder "judder" on the tray where no cover had been placed ! and a new tray needed then to be fitted before I could start.
Next bathroom ... bath gapping occurred ...no batons supports or even the brackets supplied with the bath where in place under the bath.
Next bathroom after only two months and within two weeks of the other complaint same gapping ...same reason ..their "plumber" (different guy) saw no baton / support of any description and said straight away that was the reason.
Since then, two cracks in my tiling have appeared (it was perfect when I left and had finished it)....first is where the towel rail / rad has been fitted and comes directly from the fitting point (drilled) and travels up. On only one drill point.
The second is exactly over where the plumbers installed a studding to bring the shower area forward and where original meets the new. This was plaster boarded when I came to the job,.
I only dry lined one other wall (window wall) and screw fixed to batons on one and to the " new studding on the shower pipework wall ...
The bath screen is screwed to the new framework through my tiling.
The "offending" walls are plasterboard
The plumber and his "insurer" have decided its a tiling fault ........so in their opinion my tiles have, after I left them perfect
a) Crept up the wall ?
b) Self destructed because I have not put them on right ? None of my tiling has ever been D&D
So here I am after 9 years trading, no complaints or call backs ever, no leaks, no cracks and involvement with this plumber has caused the above.
I need some help and advice as to which way to handle this .....I am hand on heart in belief this is not my tiling at fault. there was no movement in the walls before tiling ......even the plumber said himself to the customer "if the walls were not right he wouldn't have tiled them"
he knows how particular I am.
Can anyone offer any guidance..... this situation is totally alien to me .....I need to defend myself
Is there an independent company who will assess this for me / the customer and provide an impartial report.
Thanks for any help that may come my way
