Discuss Help! - Is 40mm to short on a brickbond wrap around in the British & UK Tiling Forum area at TilersForums.com.
jrm
Hi guys,
I'm finally ready to start tiling today and have made a staff marked with my tile widths and grout lines.
It looks like i'll have only 40mm on one row that will wrap around to the adjacent wall. The tiles are 400mm wide...do you think 40mm is too small of a wrap around and would I be better off continuing on the next wall with a new tile instead?
The other row is fine and i'll have just over half that which will wrap around.
Cheers :thumbsup:
jrm
On the pic below, the shorter cuts that wrap around on to the next wall are only 40mm:
jay
hi i think i know what you mean looking at the drawing diagram a move tiles over tostart full off door jamb ;wall b you just need to change bond to suit wall a ;wall c try to go full tile from adjorning corner might throw window out but try it :8: on the computer:)8: easier to set out room on job but thats not gonna happen)
Alan.P
MMmmmm, I see what your doing, each tile that cuts into a corner your using to continue onto the next wall, am I right ? Interesting, I don't do that, I work out my cuts to give the biggest available cut on each row, yes it uses more tiles but I think the end result makes up for the extra cost, in Visio, I think it is your using, how does the layout work if you were to move the set out to the left so tha the cuts on the right hand side of the door ( 40mm ish ) as we're looking are no longer needed ?
tommyzooom
1,083
Ireland
I also wouldnt use the offcuts to start the next wall, it would be very hard to get it right everywhere and what if your walls were not plumb?
set out each wall and if yourfirst row ended with a tile less than half, start off the next wall with a row that begins with a tile more than a half.
Remember with brickbond you can centre your tiles on a line equal to one quarter of the width af your tiles( so for a 400 tile centre it at a mark 100 in) This will still give you equal cuts on each side,but on alternate rows.:thumbsup:
jrm
I've tried everything to carry the pattern around the wall but it just won't work, the only solution I can think of is using a different size tile which isn't going to happen!
I'm going to use the most recent layout I posted above....that's unless a pro can tell me how I can carry the pattern around the walls without having slithers on the corners, I don't think it's possible but i'm happy to be proved wrong :thumbsup:
Alan.P
OK, first question, why have you altered the horizontal layout, I thought that worked ? Second, if you can give us some dimensions to an untied layout, plus tile sizes, plus grout, we might be able to come up with something, I think a hybrid between drawing 1 & 3 but we'll see. Out of interest, where do you hail from, maybe someone could pop around to have a look see
Reply to Help! - Is 40mm to short on a brickbond wrap around in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, Im after advice tilling my kitchen walls behind hob, sink and under wall cabinets...
Hi, Running a small bathroom job for a customer. Customer really wants to use a particular...
10K
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
6K
Firstly apologies for the hand drawn half scale drawings. 1/3 brick bond in a small bathroom...
9K
Tilerdurden
Hi Guys, I've popped over from the plumbing forum. I'll be doing a bit of tiling in a bathroom...
9K
Spare Tool
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
