Guest viewing is limited
Discuss help levelling -up swimming pool floor in the UK Tiling Forum area at TilersForums.com.
Diamond Pool Finishers
any suggestions for what i could use to level the floor of a swimming pool that has been insulated with metal panels that have been tanked with a spray-on tanking system epoxy ,with the last coat containing sand as a mechanical key for the tile adhesive , ordinary SLC is no good as it will not tolerate permanent submersion :thumbsup:
bugs183
Oh thats not good news is it. I know the adesilex can be used as a leveller, but i dread to think how smooth it would be. Bal don't make anything that will suit your purpose, and i may be wrong but i really doubt F-Ball do either.
How about a self levelling epoxy flooring product?? Surely Mapei have one of those????
K
kevin.young
Hi
we had the same problem the sand & cement base we did a year ago was all over the place and we had to flatten it out the best we could. We contacted ardex and they said to use their 301 ( think from memory its called that) its a leveling compound which can be used internally & externally and they said it was fine for the tank of a pool, it trowels and smooths out like an ordinary latex. give their technical line a call to see if its right for your job.
kevin
Ajax123
1,213
Lincolnshire
the issues with adhesive manufacturers is hat generally is their specialism. I think you need a thin screeds specialist. Have you tried Tremco or Flowcrete. Or even Sika who have specialist waterproof stuff.
Reply to help levelling -up swimming pool floor in the UK Tiling Forum area at TilersForums.com
First off, thank you to everyone that posts on this forum, although this is only my second post...
Dumbo
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
