Discuss help - my drill is slipping !! in the British & UK Tiling Forum area at TilersForums.com.
Deleted member 1779
Yes its this sort of feedback that helps us refine the product range.
My personal view is that the 6mm is not as robust at the 8mm when used on very hard material like granite and porcelain. 8mm wins simply because there is more guts to the drill and more diamond.
As a retailer I have a conflict. The market demands 6mm so of course we have to supply the best that we can.
The 6mm actually work really really well on glass, marble, travertine etc so there is a market for 6mm. I am looking at the BFKMX and removing 6mm but everytime we do that about 50% of our survey say to keep it in.
The jury is out on 6mm when used on tough porcelain. For now it stays as part of the BFKMX kits. I have put a comment on the website to say that we recommend the 8mm where possible.
If customers do use 6mm please bear in mind the advice not to apply pressure to the tips. And yes there is a mild chance of bending the 6mm as it pushes out of the back of the tile and gets caught. The 8mm is too strong to bend.
Thanks for approaching us on stand. We take the views of customers seriously. These next few months are important ones for us as we finally bring the kits to the retail market.
Deleted member 1779
Drilling multiple holes should be a doddle.
A bit of dry drilling (for a few seconds to get a pit formed) wont kill it. Just get it into a bucket of water to cool of as quick as you can after 8 seconds of drilling.
Dry drilling to start off wont kill it provided you dont drill for more than 8 seconds.
If the drill plate itself is dry it will grip much better. However even on wet tiles it still grips. The more you push it, the more it grips!
Reply to help - my drill is slipping !! in the British & UK Tiling Forum area at TilersForums.com
Hi there, after a little help. Just installed a picture wall with tiles in my bathroom but...
  • Sticky
Good morning, i took voluntary redundancy that kicks in at the end of September. I did a home...
Hi All So around 10 years ago (i had no idea it was that long ago until i looked up the order...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
