HELP!!! my tiles are falling off
mikedavey
I'm tiling a bathroom put a new bath panel which is a new piece of ply. I gave it 2 coats of BAL SBR BONDING before tiling using blue star. When i went back the next day i touched one of the tiles & it just fell off. I was horrified & was really wooried all the rest will fall off very soon. What did i do wrong? I'm having to use no more nails now.
Can anyone help me please?
use mosaic fix for them...or white star...in future backerboard is better than plywood.....Gaz
BAL Mosaic-Fix Tile Adhesive
A bright white, non-slip, water and frost-resistant, cementitious wall and floor tile adhesive specially formulated for fixing mosaic tiles including glass mosaics. It is also suitable for fixing ceramic wall and floor tiles, metal or glass tiles, marble, terrazzo, and natural stone in interior and exterior locations. Suitable for use in swimming pools. Can be used on most surfaces including MDF (in internal dry areas).
Never heard of Bal Bond or Blue Star
When tiling onto plywood I always use Mapei Kerraquick - cementious flexible adhesive. Never prime. Never fall off. You shouldnt need to prime plywood if using flexi - think that is your problem
balbond sbr aids in the adhesion process..it is the blue star or the tile type to blame here....me thinks..
exactly gazza................white star is good for ply on walls etc...but if its porcelain then switch to powdered flexi gear.spf...
A good tiler will always make sure that he is familiar with the products that he uses and their limitations. All manufacturers supply technical specifications for their products. Most manufacturers have a technical helpline if unsure.
I've almost finished the whole job though........Is it a matter of time till the rest fall off?
how well fixed is the panel and what size ply ? havent used ply on bath panel for 20 years it doesnt work very well
I only used ply as it had ply fitted before. I replace it cos the old piece was ruined during removing the old tiles. I screwed it approx every 300mm along the lengh, top & bottom of the panel.
have been lookin up on that no more ply nick..it looks ok stuff...can be used in wet rooms as well...
Leatherface even my misses :lol: anything more than ply its a funny world they will build a shower out of plaster board witch :joker: gets wet but wont make a bath panel out of it which doen`t if ply gets wet it moves if plasterboard gets wet it goes soggy which means you have a leak i know which one would b easy to change Pete
It may be because your adhesive was drying before you got to put a tile on it. As a rule, only spread enough adhesive that you can cover with tiles in 30 minutes.
Also, from time to time, stir your adhesive bucket to keep the top of your pot nice and damp..... (no innuendo's please....lol)
Dave it would be cheaper :lol:
Lets Ban Ply :thumbsup:
And Gaz :grin:
blue star no good
mosaic fix the way to go
hada huge failer with blue star once 50m of shiny new tiles on the floor :ninja:
Blue star would have be fine although not ideal as white star or D20 would have been better.The problem has stemmed from the application of the bonding agent SBR onto the face thats receiving tile as with blue star this is not required although its recommended to be used on the sides and back. My advice would be to contact the technical helpline, on 0845 600 1 222
blue star on ply??? even with super duper primer
wouldnt use blue star even if the ply was marine ply 6" thick n screwed every inch
nnn primed
mosiac fix
sorry no offence ment just ranting :ninja:
mikedavey,
Ric,
mikedavey,
Ric,
