Help needed brick bond bevelled tile
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to do brick pattern using bevelled edged tiles that are 200 x 100 & using 2mm spacers.
Wall 1 - 3230mm
Wall 2 - 2330mm
Wall 3 - 2330mm
Wall 4 - 2260mm
I’d be really grateful if someone could help me work out best corner cuts or any help you can offer. Thanks
Wall 1 - 3230mm
Wall 2 - 2330mm
Wall 3 - 2330mm
Wall 4 - 2260mm
Pictures would help so we can see the set out of the walls. Is this kitchen ?
DiyTiler,
DiyTiler,
DiyTiler,
DiyTiler,
