Plumbing Tiler
Hi everyone,
I am in the process of quoting for a job which is a bathroom and along one wall it has boxing built from 18mm exterior ply to hide the plumbing pipework to the bath, basin and wc and the wc and basin will be the wall hung type fixed onto to this boxing, the customer has not yet confirmed the type of tile so I'm afraid I don't know the size or material yet.
My question is what adhesive would you suggest to fix to the ply?, even if the tiles are on the smaller side I am thinking a ready mixed adhesive wouldn't be the best choice and a powder mix would be a superior choice, I am slightly concerned that with the wall hung wc pan there may be some movement when the customer sits on the toilet!, my options are quite limited locally, so my choices are Weber or Granfix, although if I make a bit of a journey I can then get Bal or Mapei, so I will go with whatever you guys recommend?, also what would be the best way to prime the plywood to ensure the best fixing possible?
I have toyed with the idea of fixing some 6mm Hardibacker board onto the ply to tile onto as well, again, what do you all think?
Thanks in advance everyone, any help much appreciated
