glasgow
If you want the trim used to finish off the edge then your tiler would be able to measure the finishing position of the mosaic, fix the trim and skim over an area of 30-40cm and no 'kick' will be noticed on the last piece of tile.
Check to make sure the trim will not be visible through the glass mosaic.
Use the same colour/finish trim as the shower frame and the edge will 'blend in' rather than 'stick out'.
The trim will frame off the tiled area and give you something to seal up against if your concerned about water ingress.
Hi John, thats what I would expected to happen but it wasn't even suggested.
For a variety of reasons and alarm bells ringing from his return visit we've decided to not go with him, can someone recommend a good tiler in Glasgow/Paisley/Renfrewshire area?
