Discuss help required in the British & UK Tiling Forum area at TilersForums.com.
Smudger
AFter ply, as long as there is no movement and all joints are supported, I always tank with dura wp overlapping tray by 100mm and up base of wall. Then lay ufh on mebrane and tile. If the ply is solid then I don't think the 6mm board is necessary. I also seal all edges and underneath of ply prior to fixing in case of residual moisture later (many plumber now use speedfit running under the floor and the have a habit of failing). Not had any problems so far.
Oh, and don't forget to check the levels of floor, ideally everything running slightly to shower, definitely no fall to walls or corners.
Reply to help required in the British & UK Tiling Forum area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
help required
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
