Discuss Help restoring a terracotta tiled floor in the UK Tiling Forum area at TilersForums.com.
dafydd
Good evening guys,
Im after some advice, i have just moved into a new home (a 20 year old barn conversion)
The flooring that is in the kitchen are terracotta tiles, which have been waxed for years with trafficwax.
Unfortunately the previous owner... my mother in law has sprayed some cillit bang on the floor which appears to of stained it. Im looking at stripping it back and re waxing.
Ive tried LTP Grimex heavy duty grime remover, and followed the instructions but this has only just dented the problem. Is there any thing more abrasive i can use. Any advice from the experts would be welcome
Cheers Dafydd
DHTiling
Good evening guys,
Cheers Dafydd
Grimex is not enough for it..
Can you provide some pics..? The cillit bang has more than likely just as mentioned above removed some surface grime/wax build up..
dafydd
I hope these can be seen.
Look forward to the advise
Dafydd
Marble Life Ltd
Good evening guys,
Cheers Dafydd
Dafydd
As I mentioned in my previous post you need to completely strip the floor using Aqua Mix Sealing & Coating Remover and Aqua Mix Heavy Duty Tile & Grout Cleaner. Then allow the floor to thoroughly dry (around 48 Hours). Then my choice would be to apply a penetrating enhancing sealer such as Aqua Mix Enrich and Seal or LTP Colour Enhancing Sealer. The Aqua Mix is better but it's also a lot more expensive so the choice needs to be yours. Do a small area first as a test . Pick the dirtiest tile or the worst to conduct a test area with the whole process to make sure it meets your expectations.
KM
MLL
Reply to Help restoring a terracotta tiled floor in the UK Tiling Forum area at TilersForums.com
Hello everyone, new to the forum, nice to meet you. A tiler recommended to bring this question...
A long post and not tiling but I hope someone can help, I'm trying to get some decent...
Hi, I am a old forum member from several years ago who has just signed up again. Like many...
Blunt Tool
Hi All, I urgently need some advice and not sure where to turn. We are having some major...
5K
Rookery
H
Hi all. I've got a job with these fore-mentioned terracotta floor tiles and wondering which...
6K
Time's Ran Out
TF Group Please Join
