geordie13
Hi there,
I'm a DIYer tiling my bathroom and find that the window is jutting proud of the rest of the wall. To the left and top & bottom centres it is 3 - 4 mm out, but to the right and rh bottom, it is 10 - 12 mm out.
My first thought was to take the angle iron off the window and cut the plaster back to the line of the wall. Messy, time consuming and I would only be going back 3 - 4 mm.
Looking at the floor adhesive, it can be laid in beds up to 20mm. Could I but a thick bed on the wall and fill the gaps when tiling? If I do this would it be better to fill the hole with adhesive first to give a reasonably flat surface for tiling?
Also, would it be better fitting a row of tiles at a time and allowing the adhesive to set before fitting the next row?
The tiles are ceramic 60 * 30 cm.
The local supplier stocks Ultra Profix would this do the job.
I see from the forums that Bal is the adhesive of choice. Why? Is it easier to work, does it grip the tile better. I live in the sticks and the nearest stockist is some 45miles away, so using the Ultra would be easier, but would the Bal be advisable?
Thank you, Ed
Thank you, Ed
