Discuss Help with 15mm plywood sub floor in the British & UK Tiling Forum area at TilersForums.com.
campbell
Hi All,
I think I have bogged up! I have cut all my ply so that I have a 20mm gap all around the perimeter of the bathroom.
I am told it should be 8 - 15mm for expansion. I will be laying a ceramic tile of some sort.
There is no skirting fitted to the walls.
Please tell me there is a way round this! Plywood is expensive!!!
best regards..........Campbell:oops:
grumpygrouter
The gap does seem a little large but is it really going to be a problem? the edges of the floor are not really traffice areas so should not be subject to much loading of any sort so you should be able to overlap the edges of the board without too much problem I would have thought..
Is the wall going to be tiled or is it tiled already?
V
Verona
Either way you tile it you have the gap but as Grumpygrouter said, there wouldn't be much loading on the edge so it should be ok.
However, I would say you have done it is the right order by tiling the floor first as then you get a nice edge on the wall tiles meeting the floor. This is how we always do it in Italy. :smilewinkgrin:
Reply to Help with 15mm plywood sub floor in the British & UK Tiling Forum area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
