Help with awkward-shaped bathroom
Minnie
Hello
Hoping to get some good advice here. I'm attempting to do my first ever tiling job, and now that I'm unemployed, on a tight budget so can't afford plasterers etc.
It's a council house just over 100 years old and it looks like the current tiles have been placed onto a concrete wall. There were three courses (not sure if that's the correct word for a layer!) of 15-15cm tiles. The top two I've got off with no problem and have managed to get the adhesive off easy enough, but it looks like the bottom layer of tiles have been laid onto something more concrete based. I'm not sure why and I'm not sure whether to hack this off or if it's covering up something bad.
That's the first problem. The second problem is there's a few funny angles. Some people have said I'm better of sticking with small tiles, whereas others have said to get big ones for the horizontal parts and cut them (obviously more wastage if I go wrong)
I've plenty of pictures if anyone's interested.
Hi Minnie
welcome to the forums :welcome:
You've come to the right place. if you can, please upload photo's to this thread you've started so that our members can see more clearly the wall substrate, remaining tiles and whatever they're stuck on with.
A lot of our professional tilers are at work during the day so please don't be put off by a slow response to your questions. Oh and the more questions you ask, the more you learn :thumbsup:
Liz
First of all, I'll stick up some pictures of the bogey-coloured tiles and the awkward shapes if that's ok. Think I need to take more photos of the walls as I did them in poor light last night, so will post them up later. (Tiles were laid by council over 25 years ago so they're not my b/f's choice!)
Back of bath
Back of bath picture by Zed_02_2007 - Photobucket
Back left
Broken Link Removed
Middle-left
Broken Link Removed
Front-left
Broken Link Removed
Front
Broken Link Removed
Window. The tiles never went up to the window ledge but I'm planning on maybe taking them up to the window ledge to cover that bit of wall
Broken Link Removed
Sink left
Broken Link Removed
Above sink
Broken Link Removed
Enjoy
PS: I see you've already earned your wings!
Your walls are a mess and would need priming. Use some smaller tiles you will have a nightmare with big tiles with all the angled cutting
You have some bare undercoat plaster which is very soft, as you stated you cannot afford to get it plastered which it seriously needs. Is there anyway to get the council to do anything for you on this job.
Priming is to seal the areas your going to tile
No, Council hasn't done any decorating here for over 20 years! It's down to the tenant.
whereabouts are you minnie? maybe one of our members would pop round and price for prepping
South London. You did see my comments that I was unemployed and couldn't afford anyone didn't you? :smilewinkgrin:
I did Minnie, if I wasn't at the other end of the country, I'd offer to pop round and advise on the state of your walls etc, unfortunately I'm up north:smilewinkgrin:
The weather's much nicer down South. You should come down and get some sun on your face :smilewinkgrin:
Anyway, I'm going to stick up some more photos in a sec so you can see the current state. I took the tiles off the horizontal bits today and discovered white tiles on the left-hand side of the bath and plywood in front. No photos of those bits yet though.
Back of bath
DSCF0477.JPG - DivShare
Side
http://www.divshare.com/img/display/9270514-d70
Front
http://www.divshare.com/img/display/9270537-1c9
http://www.divshare.com/download/9270514-d70
Front again
http://www.divshare.com/download/9270351-0bf
Sink
DSCF0479.JPG - DivShare
This is what's under the bottom layer of tiles
http://www.divshare.com/img/display/9270347-f5a
So, how many tiles high will you be going to fix
Well, the vertical from the bath up to the window ledge is 72cm. The tiles didn't originally go up that far which made it look a bit silly with the tiles above sink going higher than those above bath, and as that bit under the window's pretty crappy, I figured tiles would cover it.
I have no idea what tiles to use now. I had thought about 25x33cm as that would leave a 6cm space for a border, but people are saying I'm better off sticking with smaller tiles, but I figured that would take me forever. There were already around 120 tiles there without allowing to take it up to 72cm.
Unless I hack that what looks like cement/sand based stuff off, then I'm going to have a wonky wall, unless I fill it in to a smooth base (that's me guessing)
The tile size is not that big but you would need a cement based adhesive looking at the state of the walls, you may need to build up in certain areas.
To be fair, even a good tiler will have his work cut out for himself on those walls.
Do you have a friend/relative who could help you out
Go on, fill me with confidence!
Friends/relatives? Not any that do tiling.
Why do I need a cement based adhesive when the tiles that were stuck on above the first layer weren't stuck with cement based? I'm not questioning your judgement, I just want to know the difference.
Tubbed adhesive can be fixed with a 6mm notched trowel and have a bed of 3mm max and is air drying, so for the size of your tile would need a few weeks to dry properly.
Cement based adhesive, even a slow setting one cures by chemical reaction so would be more suitible for your size tile so grouting could applied the following day
Well I'm not necessarily going to use 25x33cm, I just figured it would be fewer tiles to lay, but then I have the problem of the horizontal surface.
Do you think every bit of wall is in a chronic condition or just certain ones?
Is the cement based adhesive to do with the size/weight of the tiles or because of the condition of the walls?
I know the one above the sink is bad. It looks like there were nails/screws in there at some point and someone's tried to fill the holes. I was thinking of putting a mirror there to disguise that certain bit of wall.
PS: Thanks for all responses so far
Under the circumstances this what could be helpfull;
Use a smaller tile, 6x6 or around that size then you use the tubbed adhesive.
Cement based is both in the curcumstance.
i would prime still where your going to tile because of any powder/dust.
Yes you may have to hide that certain area with a mirror.
You could use the remaining primer for the rest of the bathroom before you paint just to seal the surface.
A good box of filler to cover any cracks/faults in the walls.
Sand down then paint.:thumbsup:
Would it look silly to use 6in tiles on the horizontal and bigger tiles on the vertical?
Was planning on putting some primer on the whole wall as there's black mould on top of the paint. Didn't realise you put it underneath tiles though.
Have planned on filling in all the cracks and holes and then sanding. I know sanding's going to be a nightmare, and I know that an electric sander would cause a huge mess, but would it damage the walls? I'm not sure my wrists/shoulders are up to manual sanding.
bleach ain't gonna cure it Minnie (managed to open pics:hurray🙂 council have a "duty of care" and a "decent home" mandate to adhere to. Insist on a home visit with an Environmental Health Inspector, that black stuff aint gonna go away with bleach:thumbsdown:
Yes, everyone was supposed to be getting new kitchens and bathrooms before 2010. That ain't gonna happen apparently. Lambeth didn't get the funding and it's not going to happen until 2011.
Thing is, I want to get it done before Christmas as a sort of Christmas present for b/f. I had already told Lambeth that b/f had already had pneumonia and respiratory failure, but as far as they were concerned, I should open the window and clean the area with bleach.
Won't that primer stop the problem if I repaint and start ensuring the fan is used?
Bathroom Tiling Advice
Unsolved
Minnie,
Minnie,
Minnie,
Minnie,
