L
lendini
hi all.if i take off old tiles around bath area and find that the old substrate ie plasterboard is totally wrecked by the process what are my options.I have read on dot and dab a new peice of plasterboard or backer board on.i suppose this is over the old plasterboard with it all still in place do i need to prime.Also is it possible to screw it instead of dot and dab if i locate the studs.
Next question is once i have added the plasterboard on plasterboard the wall will become thicker and now i have the problem that the bottom of the wall where it meets the bath edge is now going to overlap quite a bit,would i then be forced to shift bath over a little.
last question if the plasterboard on plasterboard stops halfway along a wall there would be a noticeable thickness on show.how do you guys overcome this.Thicker tile trim etc.All help appreciated and thanks in advance
