Discuss help with plumbing a shower in the British & UK Tiling Forum area at TilersForums.com.
Don't discount a problem with the boiler. A few years ago I fitted a Mira excell to a system fed by a combi and had a similar problem. All the taps worked fine but the shower kept running cold. It turned out to be a split diaphragm in the alpha boiler, the flow rate through the shower was slightly less than that through the taps and wouldn't quite operate the microswitch on the boiler.
Mike
Reply to help with plumbing a shower in the British & UK Tiling Forum area at TilersForums.com
