Discuss Help with quote in the British & UK Tiling Forum area at TilersForums.com.
F
Fred
Council swimming pool gents changing room. Main area with three smalled rooms all inter-linked, no doors. 62 m2.
Remove all old 200 x 200 wall tiles. Make good the walls. Supplied wall to floor trims for flooring to be fixed by me.
Tile 100 x 200 slip white tiles to all walls. Supply adhesive and white grout and corner trims, around 12.
I'm lost for a price, so advice please , thanks, Fred.
chris.tiling
Poole
Day rates for removal and prep - materials cost depends on what you pay for the gear - should be able to work that out yourself from previous invoices / knowledge of coverage. Fixing new tiles - look at time you think it would take and cost it on day rates, then also look at metre rate and see what figure fits both you and the customer best. Dont sell yourself short on prep time - as Doug says you dont know what making good is needed until old tiles removed, so either build in time, or put a variable in on quote
Good luck Fred - hope you get it as it sounds a nice job
White Room
I use to a price book called Wessex and used there guide for many years when plastering and have found it invaluable. Making good would have wait until your've seen whats underneath the tiles.
For taking up tiles half an hour per m2and loading into a skip as a guide, then any goods you need to hire or labourer that may be required
Reply to Help with quote in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Hi, hoping someone can help with advice. We purchased 600 x 600 tiles for our bathroom floor...
Help with quote
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
