Discuss Help with tiling onto ply overlay. in the British & UK Tiling Forum area at TilersForums.com.
Jeffrey4670
Hi, I intend to tile a bathroom floor this week. I have problems in using anything more than 6mm external ply. Would like to use more, but not able to. I am fitting 6mm ply directly onto T&G floor boards. I intend to screw approx 100mm centres. I intend to over kill the fixings to make sure it's secured down. Do I PVA to the underside of the ply & joints or do I use P51 primer? and what reason is this for, please? Also do I use Ardex P51 on top of the ply for the adhesive to take. I will be using felxi-Adhesive & flixi-Grout.
Something like Ardex 7001 adhesive. Thanking you, Jeff from West Yorkshire.
Dave-T
might just be me, but as a rule, i allways use fastflex if im laying on wood. If it was me, i'd fastflex 6mm dukkaboard to the floorboards (thicker boards if possible), then fastflex the tiles on top of that. then grout with lashings of gt1. Works out more expensive i know, but ive never known floors to crack up with fastflex. you never really know how much movement theres going to be with wood, so i just never risk it.
Maybe i'm just overcautious.
grumpygrouter
Recently did my kitchen floor. I overlayed with 9mm wbp ply and used P51 primer along with Ardex 7001 - it's not coming up!!!!!
(I know the ply is a little thin guys but it's sat on 25mm T&G chipboard and I had room constraints).
Be brave and mix the 7001 as per the instructions on the pack, it should be very thin, apparantly this gives a solid bed. I had mine a tad too thick I think, but it still went down well.
GazTech
The answers were out there somewhere !
Reply to Help with tiling onto ply overlay. in the British & UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
