Discuss Help!!!!! in the UK Tiling Forum area at TilersForums.com.
Well guys, half the bathroom complete and you can almost hang from the tiles.....very weird the tiles not sticking to the adhesive screed on the wall and yet when adhesive applied to the tile then stuck to the wall no problems??????
You don't sound like a tiler are you a shop assistant ?Give it time and they will all fall off. Grey Cement based adhesives and plaster board or plaster dont go together unless you prime them.
No but a lot of tilers would also say you need to prime plasterboard I thought the idea of this forum was to encourage and help the less knowledgeable the guy is not a tiler and do you think you could be wrong about the primer and a little aggressive with himSo if i was shop assistant would that make me less knowledgeable then?
Just to add here , Pete is correct.
Priming plasterboard is not a necessity as the adhesive is not in direct contact with the gypsum core.
It does not hurt to prime as it can extend the open time as moisture isn't sucked by the paper and IMHO , this is probs the cause of the first failure.
Moisture sucked by the paper and tile biscuit , so back skimming would have helped with the best contact.
Discount tiles ..... Always read your replies before you hit the enter key and think if it is worded without causing offence. We all like a happy forum.
Reply to Help!!!!! in the UK Tiling Forum area at TilersForums.com
