Discuss Hi everyone, new member advice please. in the British & UK Tiling Forum area at TilersForums.com.
N
nolly
Hi everyone I am a very capable but non professional DIY'er. I am soon to embark on something new though and would appreciate some advice on the matter before I decide on the best way to proceed. I have a small en suite which is going to be stripped down to bare walls and floor and my intention is to install a level entry tiled hidden tray, obviously I am going to tank the walls and floor accordingly but this is my dilema. I keep looking at the Linear style drainage systems which just appear more stylish and certainly seem easier to tile. The problem is that the most pratical one i have found is the Novellini Wet Dec which is very expensive, however this comes complete with pre formed slope and drain so installation seems simple enough. My concern is that this item does not have a clamping frame for the membrane and only appears suitable for TILESAFE which i do not want to use as this seems overpriced and I do not see it as the best option for the floor ( was looking at Schluter Kerdi or Durabase CI and Wp for floor and walls).
Has anyone succesfully used an alternative membrane on the above wet dec and if so how was it dressed into the drain, if not would it be possible to use durabase CI on the floor but fashion a dressing mat out of an off cut of TILESAFE? Looking for any ideas or help.
I am waiting for my fractured hand to heal so have plenty of time to research. Cheers Nolly.
N
nolly
Thanks for the response. My concern with the TILESAFE was de coupling more so than cost, if TILESAFE offers some flexibility for this then I may well opt for TILESAFE on the floor and Durabase WP on the walls. Still un decided on the base as from what I have read it appears that the TUFF 2 trays are the best.
Cheers Nolly:thumbsup:
DHTiling
Not a wet tray i have heard of, but i have used the Tuffedec2 a few times.
And i have used Durabase ci and wp on it..It advisable to rough up the tray with sandpaper to provide a grip for the flexible adhesive as the trays are shiny..but apart from that the Tuffdec2 trays are very easy to install and low drain waste heights help as well..
The tilesafe is a self adhesive membrane and easy enough to install but where you overlap the joints , i think it can cause a ridge and you need to over come this when tiling.IMO..
Reply to Hi everyone, new member advice please. in the British & UK Tiling Forum area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
