Discuss Hi forum members in the Canada Tile Advice area at TilersForums.com.
Man2eep
Hi,
I am looking for some advice, we have recently have had a extension done. The entire ground floor is wet underfloor heated. The floor is suspended floor joists with the pipe runs between the joists. A wpb ply board has been screwed down on the joists. The floor has then been tiled using 600mm by 600mm porclain tiles with a flexible adhesive. Soon after tiling and when the under floor heating was on, we noticed some tiles were loose, now over a span of a month loads of tiles have popped up and the grout cracked almost every where. What has gone wrong and how can we rectify this disaster ? Some people have said we should have used a backer board screwed to the ply and then tiled? Any assistance/guidance will be appreciated. Thanks
I
Ian
Most adhesive manufacturers state that heating should not be turned on for 28 days after the completion of the installation, this is to allow the adhesive to reach full strength. Also, it should be turned on at its lowest setting and then the temperature increased by one/two degrees per day so as not to 'shock' the floor. I'd still like to know if the tiles have debonded from the adhesive of the adhesive from the floor, a couple of pictures will speak a thousand words, if you can remove a loose tile or 2.
Man2eep
Hi Bri, the UFH went on as they completed the tiling process. As we walk over the tiles, some tiles are literally loose and seem de bonded from the adhesive. Later today I will lift up a tile and look to see whether the adhesive has de bonded from the wpb board.
Is it right to believe that porclain tiles should never be laid directly on wpb board. That there should have been a 12mm backer board screwed on the ply followed by flexible adhesive ?
thanks
I
Ian
thanks
A 6mm backer board would have been fine 12mm is more for stud walls, the backer board would undoubtedly have been a better surface to tile to, also, the backs of the tiles should have been skimmed with adhesive as well as troweling the floor, this will help to achieve a full bed of adhesive and assisting adhesion to the tile. Just another thought, was the floor deflection (bounce) free after the ply was fitted? Is there any chance that excess movement has caused the tiles to debond?
Man2eep
Hi Bri, the substructure is on 9" joists with noggins. The ply is 18mm thick. Under the joists they put a course of brick to keep the joists tight. The suspended floor was/looked very rigid, there wasn't a bounce. I can only imagine as the heating kicked in it has warped the ply resulting in the tiles popping up. How can I send pictures. Thanks.
Man2eep
Reply to Hi forum members in the Canada Tile Advice area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Hi forum members
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
