Discuss Hi from Mojoammo @ Jason E Mulligan Tiling in the British & UK Tiling Forum area at TilersForums.com.
mojoammo
last week I got a call from a customer complaining of cracking tiles. The job in question was a complete bathroom refit, the existing plasterboard walls were removed and the room was re-sheeted with 3/4 inch exterior grade ply, fixed securely to the stud work, fully primed and tiled with a flexible adhesive and grout.
This was 4 months ago and now a crack has developed on the bath wall, extending from the rim of the bath to the ceiling, straight up and creating a valley in the tiles. As the tiles are still securely fixed to the wall, the customer has stated that they do not consider it to be a fault with the tiling, but as always it is the Tiler who has to fix it. I think that some movement has occured with the stud work, as the tiles are concaving where the crack is, hence the valley effect.
I am due to strip, investigate, and repair this on thursday, however if there is movement behind the ply sheeting, short of taking down the wall, how can I be sure this will not reoccur in another couple of months?
Reply to Hi from Mojoammo @ Jason E Mulligan Tiling in the British & UK Tiling Forum area at TilersForums.com
5K
  • Sticky
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
Hi all, I was hoping to get some input/help on this situation. Background: We had 12 x 24"...
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
