Discuss Hi. I am a retired guy (philip) thinking of marble tiling the bathroom in the Bathroom Tiling Advice area at TilersForums.com.
philip.surdival
Having had a guy with 40 years experience in to re-tile the bathroom in marble the tiles started to fall off within a couple of days. He used two part adhesive onto a plaster base but the adhesive appeared to reject the tile. Any advice would be welcome as I don't fancy a 5-6 Kg tile falling on my head whilst bathing.
Bubblecraft
Hi & welcome to the forum. First & foremost, you have tile weight issues with your substrate. A plasterboard wall can take up to 32kg pm2. A plaster skim greatly reduces this to 20kg pm2. Depending on the thickness of your marble, you are greatly exceeding these weights. For example, with adhesive & grout, tile weights are as follows:
10mm Stone - 31.10kg pm2
12 mm Stone - 36.48kg pm2
20mm Stone - 58.00kg pm2
I would sort your substrate before commencing any further. Hardibacker is the direction I would be heading.
What did your tiler have to say about the tiles falling off?
philip.surdival
Hi Bubblecraft. Many thanks for the information. There are three substrates that the tiler has been working onto. The floor is ply (I believe 15mm), two walls are standard plaster from the original 60s build and two are non-skimmed plasterboard (dry-line). The tiles are Mira Grey Marble 61x30.5x1cm (from Prestige Stone). The given weight is 20.4 kgs covering 0.774 pm2 working out at 26.35 without adhesive and grout. Since the mishap I have told him I wish to go down the Hardibacker route. All surfaces were treated with PU prior to tiling which was carried out using Toppfix rapid set two part adhesive applied with dot and dab. Within less than 6 hours, tiles started falling. On inspection the tiler claimed that there had been an adverse reaction between the resin backing on the tile and the adhesive used resulting in tile rejecting the adhesive. The floor was laid on a combed adhesive bed but again there was non-adhesion. With this being a bathroom installation would you still recommend Hardibacker or a material more water resistant? Once more many thanks for your response. Philip
philip.surdival
Hi and thanks for the reply. Yes - I do have some not very pretty pictures but don't know how to upload them here. As soon as I learn - I will do so. But in the meanwhile all I can say is that the dabs have adhered (mostly) to the substrate/s but rejected the tile. With time some of the dabs have been dropping. Mostly they are attached firmly enough to damage the plaster when trying to get them off. There appears to be shrinkage on the dabs as they are quite 'crazed' as in land that has dried out. But a few photos will sort that one out ;).
White Room
Is PV as in PVA......And did he dot and dab the tiles with adhesive onto the walls....Just trying to get my head round it.
Reply to Hi. I am a retired guy (philip) thinking of marble tiling the bathroom in the Bathroom Tiling Advice area at TilersForums.com
11K
Rizzle from the Portizzle
Hi, im a plumber sub contracting for a firm. Now, I've began first fix on a small bathroom but...
mylocalplumber
Hello, Im looking for a bit of advice regarding a bathroom i'm DIYing in my own house. I am...
6K
mattle40
Unsolved
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
