Guest viewing is limited
Hi
Discuss Hi in the UK Tiling Forum area at TilersForums.com.
spookingtons
Thanks for the link. So all being well I should be able to just pull the current connector out of the soil pipe and pop in an offset connector. I'm hoping there is no reason I have to go in the tiled box that the connector pokes out of (i.e. a WC connector welded to the soil pipe, if such a thing is standard?) as I'm in danger of breaking tiles for which there is no spares. I'll pop the WC out and investigate further...
From your link it seems the standard offset is 20mm which I presume has enough 'give' whether you have tile+adhesive+ply or just tile+adhesive.
Reply to Hi in the UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi
Tags
usa
