Discuss Holiday Home/lodges Tiles Onto 9mm Ply in the Canada Tile Advice area at TilersForums.com.
Andy Allen
1,318
Gloucester
So If the floor boards or chipboard are solid there is no difference between 6mm or 18mm ply. If the 6 is glued and screwed every 100?
If the subfloor is solid then just overboard with 6mm cement boards or insulation boards....why would you use 6mm ply? Apart from trying to save a few quid...you ever cut a sheet of 6mm ply and seen how easy the layers come apart .
Reply to Holiday Home/lodges Tiles Onto 9mm Ply in the Canada Tile Advice area at TilersForums.com
Hello, first post, asking about career change and possible entry route into the industry. I know...
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
So I'm about to box in some pipes and tile over them - I understand that tiling directly onto...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
