Discuss Hollow porcelain tiles. in the Australia Tiling Forum area at TilersForums.com.
U
UnhappyCustomer
Long story short.
Porcelain tile laid on concrete floor. A glass was dropped on a tile resulting in a chipped and cracked tile but not a broken glass.
Knocking the tile it sounds hollow as do about 95% of the others on the floor.
Is it possible the hollow sound is a result they have not been laid property?
I would have expected a broken glass rather than tile.
Colour Republic
I would ask them to remove the cracked tile as it needs replacing now, at that point you can see how it is fixed and if the tile is fully supported.
What type and weight of glass did you drop on it? It does sound odd that the tile would break before the glass but could have been a freak of nature and the glass caught the tile on a sweet spot.
At this point I wouldn't get in to a war of words with the tiler/supplier but just explain your concerns. If they are a decent firm they will try to ease those concerns and replacing the broken tile is a perfect opportunity for them to demonstrate that the work was carried out correctly. If it was a freak of nature then pay them for the original job and also a bit on top to cover the broken tile. If not and the floor has been poorly laid, then fight them all the way.
Colour Republic
The thing is there are in excess of 100 tiles with a solid sound to them. The worst sound like you are knocking on a piece of plywood fixed to a frame if that makes sense. My concerns are about the whole floor rather than the damaged spot.
If there are 100 solid sounding tiles but 95% of it sounds hollow.. just how many tiles did you have laid!!!!
As mentioned above it could be that the tiles have debonded, either the adhesive didn't stick to the floor or it didn't stick to the tile.
You're not going to learn much until you take a tile up.
Has any grout cracked anywhere?
U
UnhappyCustomer
No grout has cracked yet.
We we are talking somewhere in the region of 200 tiles laid.
Reply to Hollow porcelain tiles. in the Australia Tiling Forum area at TilersForums.com
We had a water underfloor heating installed and tiled over. 3 months later we noticed many tiles...
Amethsyt
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
