Discuss Homebase plywood recommendation in the UK Tiling Forum area at TilersForums.com.
I have just finished a bathroom,walls and floor using 600 x 300 porcelain which the customer bought from Homebase.The customer laid the plywood floor ,when I told him that the ply was not suitable he said that,s what Homebase recommend on reading the packing it states that flooring should be plywood to the thickness of 9mm.The customer would not remove the ply so I laid Ditra over the top,is Homebase right in recommending this thickness ? I for one always go for a thickness of a least 15mm and then still try to use Ditra,just would like other tilers opinion on this.
I
ian thomas
I really don't want to sound as though I am trying to put people down but I am a 49 year old tiler with 31 years experience in the trade, I have never used hardie, always used 12mm ply, never weighed a box of tiles, to my knowledge never had a wall collapse due to the weight and never used ditra. If the correct adhesive is used there will be no problem. I still dont get why people replace plasterboard with aqua panel because its waterproof? The grout and adhesive are waterproof so the substrate should not have to be. As I said I am not here to put people down but adding these costs to a job would result in not getting a lot of work, cheers although I know I am in for a bit of stick
White Room
They are water resistant, not waterproof......
BARRONBATHROOMS
It's this lack of knowledge on new product that make it difficult for me to win jobs. I tank all wet areas, Silicon expansion gaps. Use uncoupling membranes on ufh or with stone. But because I try to do the best possible job I lose out because someone will say it doesn't need doing so can do it cheaper. Shouldn't we all be trying to improve the trade and do the best possible job?
nybor62
1,083
rotherham
so what products would you use if you were constructing a wet room , surly not plaster board?
Reply to Homebase plywood recommendation in the UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Broadstairs,Kent.
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
