E
Discuss How do i tile in corners ? in the British & UK Tiling Forum area at TilersForums.com.
its not the only way m8Lee thats the only way you can tile corners matey, one tile goes to the wall leaving a small gap, when you are doing the next wall you leave a small 2/3mm gap and you Silicon this gap when everything is dry. Dont grout it and then Silicon.
Have you prepped the walls properly? What are you tiling onto? Skimmed walls, plasterboard etc? What adhesive are you using?
hi lee, dont start a full tile in a corner mate as the walls may be off try and centre your tiles on your shower walls so you get full tiles and cuts go to the sides off this.
also leave a small gap but dont fill with grout fill with Silicon mate as grout will crack you need silicione for movement
also i wd use a white adhesive mapei keraquik wd be nice one to use for your trav mate and if your not up to speed on the siliconing then there is a product out there called cornertape this stuff is amazing to help you avheive the perfect Silicon joint
good luck
Reply to How do i tile in corners ? in the British & UK Tiling Forum area at TilersForums.com
