Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were are all Plasterboard with tiles around the room up to shoulder height when standing in the bath tub. 2.7 walls on a wooden stud work frame, 1.3 walls relying on dot & dat adhesive against the grey breeze block wall.
So far, sanitarywares removed except for bath. Plasterboards also removed up to tile height for most of the walls with just the bit around the bath left. It just occurred to me that the bath is enclosed (in L shape) by plasterboard with dot & dab adheisive so no studs to fix the Wedi onto.
My uneducated guess would be to leave the existing (already hard & flattened) adhesive on the wall, add more all over the place and press the Wedi against it. The existing adhesive is effectively acting as the stud work to keep the board level. I don't know if normal plasterboard adhesive will stick the Wedi to the wall.
Is this the way or it has to be done differently? If so how please?
Do I use some sort of edge banding on the corners to make it more rigid?
When I install the bath, can I screw a wooden baton against the Wedi board to level & strengthen it at the wall?
Also
Thanks very much
Also
Thanks very much
