Discuss How do you set out a full bathroom ? in the Bathroom Tiling Advice area at TilersForums.com.
Concept PHT
Pick a spot, drop the tile on it and mark the wall. Then get your laser level and mark the room perimeter out. Work your first course strictly to that line.
The check the spirit of that first course. If all ok (it should be), bang em on all day long!!
Factors affecting : cuts around windows / end cuts. - Obviously adjust accordingly. Using a home made tile staff will quickly identify these areas anyway.
Plus, I always wip the basin and toilet out then put it back all sealed and piped in correctly.
For the perfect job!! :)
Concept PHT
Yes I do, as it says in the description. Using a tile staff will enable you to work out where the best cuts are. Or you can do it the hard way and mark the tile across the wall / floor to see where the best cut is.
I forgot to mention about the bath too. Best to go a full tile from the bath upwards wherever possible.
Well thats what I do anyway... :p
L
Leatherface
Well here's how I do it.
1. Mark a straight line around the room at any height - usually half way. This line is the datum line ( or reference point )
2. Find the highest ceiling point & lowest floor point - First to the ceiling - use a staff and go around the room at 2 ft intervals, marking the staff where it meets the line at every point. You will end up with a series of marks on the staff -the distance between lowest & highest is the amount that your ceiling runs out. Repeat for the floor.
Knowing this will enable you to make sure that the cuts at ceiling & floor do not end up as sliver cuts.
3. Make a staff with tile & grout lines for vertical set up.
4. Choose a point where you would like to start tiling.
5. Mark staff against datum line from this point & go around the room checking what size of cuts there will be at door, window, shower, ceiling & floor height.
6. If you are not happy with any then adjust accordingly until you are happy. You will then know ( & be able to explain to the customer ) - why you have started there. It is always nice to start full tile around the bath - but not at the expense of having, for example a tiny raked cut at ceiling height.
7. Use staff also to check horizontal cuts.
Start tiling in the knowledge that there will be no nasty surprises along the way.
K
kapitan
ffs what do you do on day 2??? :wink_smile:
L
Leatherface
What do I do on day ? - I don't understand question.
Floors - I use two straight edges and a Rubi square - find the best line to take - off units or wall - figure out best line. Then use staff on floor to determine cts.
It doesn't matter if there are 10 rooms going off each other - I square off into each room - draw a line. Then with my staff work out where my cuts are in each room. Adjust - if there are to be any small cuts I decide where they will go.
Simple
L
Leatherface
Oh I geddit - practice makes perfect - it doesn't take that long wehen you've been doing it for awhile. Anyway, as you know, time spent in preparation saves time in correcting mistakes later.
Have you got that disc yet ?
Give me a bell if you want one ? Just need digi photo's & text
Cheers Nick
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
The key to setting out is to know exactly where every cut will be and what size approx. The methods of doing this have changed a few times over the years and now there's a few ways of getting your first tile in place but really, aslong as you know you're not going to be snipping away bits of tiles for the whole job trying and testing everywhere, you should be fine.
Generally on bathroom walls you've got the bath, window, maybe the basin as your main guides trying to get each of those to look spot on, like there's no better setout. Then genrally you're adjusting those slightly to make the internal corners fit in well etc etc.
I find. :p
L
Leatherface
Oh I've been rumbled :icon9:
A bit about me....
I am now the other side of 40 years old. And prior to tiling I had been in the Direct Mail Industry ( Junk Mail ) for around 18 Years. My last position was as a Production Manager in a busy factory which sent out over 2 million letters a week. It was a well paid job, I earned between 30 - 35k a year.
Anyways. I have a good mate who fits kitchens & bathrooms, one weekend he wanted a hand tiling a kitchen, so I went along to help. Liked it & decided I wouldn't mind a change of career. So I spent 12 months working weekends, holidays & sickies doing as much tiling as I could with him. My mate advised me to go on a course - so I looked on the internet. Went for 5 day course.
As I had done some tiling previously I was able to take away & use certain things that I learned that I felt to be of benefit - setting out was the main one. I still use this method & find it to be excellent. I left my job 2 years ago & became self employed.
I have since worked with many other tilers, learning tips from them & passing on my own. I am always busy & have never ever advertised.
I hope that I have already demonstrated that to some degree I know what I am talking about when it comes to tiling. This is not to say that I don't still have things to learn - I am always willing to learn & embrace new ideas & methods - If they are of benefit to me.
Regards
Reply to How do you set out a full bathroom ? in the Bathroom Tiling Advice area at TilersForums.com
Grouting my shower walls in a few days. I tried to do everything by the book, which I did. Water...
  • Sticky
Unsolved
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
